Ralph6
Jan 23, 2020Follower
How to connect AC750 to apple airport express
I need help in connecting my new AC750 range extender to an Apple AirPort express router. There is no WPS button on the router, but there is on the cable modem. Using the WPS connection instructio...
Jan 24, 2020Guru - Experienced User
You can use the smart connection wizard for setup.
The range extenders all have a video on their support site showing but the wps method and smart installation wizard. AC750 is a speed not a model so I can't link directly to the support site.
But you can go to netgear.com/support/ type in the actual model and it'll take you to the support site. Try watching the video. Its very helpful. It'll also link you to the manual that also has the walk through.
