GregNYR
Sep 13, 2020Aspirant
How to connect R8000p to EX8000 using wired ethernet connection?
Hi guys, I want to connect my Nighthawk router X6S (R8000P) to my Nighthawk X6S Extender (EX8000P) using wired ethernet connection. I believe that a wired connection would have the best speed...
GregNYR
I believe i found the answer by setting up the extender as an access point.
My question now is: Could I use the same name for the access point as the router?
Sep 14, 2020Guru - Experienced User
You can use the same name but it won't function as a "mesh" device. The mesh function only works in extender mode.
What that means is it won't roam the same. devices will tend to be "sticky" and stay connected to 1 device until they loose signal or you disconnect/reconnect.
