shelquis
Feb 08, 2012Aspirant
How to Connect to 5GHz Channel?
Hi, I've got a WNDR3700v2 that's an access point for an XP and a Win7. On the Win7 machine, I can only connect to the 2.4GHz channel. When I click on the signal bars in the task panel and bring up ...
jmizoguchi
Jul 03, 2012Virtuoso
TBW wrote: I have a 3400 router and have the same issue, the blue light never blinks. Looking and my lan card on my laptop, it does support 5GHz:
Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC
I tried enabling 11n AdHoc but that didn't do it.
Any suggestions?
ad-hoc are not going do any for connecting to wireless router . ad-hoc is for other wifi device to connect your laptop directly
if you are wireless do NOT support 5Ghz than not use of trying. replace the PCI-C card with dual band support card or buy USB wifi adapter instead
