NeoGeo
Oct 06, 2012Aspirant
how to deactivate WPS on WN3000RP ?
hello, i found an option in the WN3000RP interface which is called. "hide WPS number" (the 8 digit number). i marked this to hide the number but i dont know where the sense is to hide it? i c...
jmizoguchi
Oct 06, 2012Virtuoso
You may need to suggest the fixes to support. If you can not disable 100% in GUI right now then I don't think you will find the solution right until firmware changes.
my.netgear.com ... put trouble ticket here
