Michelebou
Aug 16, 2019Aspirant
HOw to disable Ap isolation in Wn2000Rpt-2 in order to get chromecast to connect ?
Windows 10
Christian_R
Aug 21, 2019NETGEAR Employee Retired
Hello Michelebou - You will need view the extender's advanced settings. Please refer to page 25 of the user manual linked below and clear the Enable Wireless Access Point box.
http://www.downloads.netgear.com/files/WN2000RPT_UM_05MAR2012.pdf
- MichelebouAug 30, 2019AspirantThank you Kudo,
I just can't get to mywifiext
It always says : YOU ARE NOT CONNECTED TO YOUR EXTENDERS NETWORK
Any idea why ?
Thank you !- Christian_RSep 05, 2019NETGEAR Employee Retired
Michelebou - Please ensure that your wireless device is connected to the extender's network to access mywifiext.net. You may also try other wireless devices.
~Christian
