SwapnaSoni
Mar 24, 2020Follower
How to find IP of WIFI Extender EX3110
Hello Team,
How do I find out the IP of the Wifi Extender.
I recently registered the device, connected the hardware near the wifi router, the device is able to settle with Green LED on 'Router' LED and I am able to observe the wifi connection - under wifi connection options. But there after it doesnt accept my username and password. The other option to connect is through IP address but I am not able to fetch the device IP address.
Could someone please help.
Thank you in advance.
Swapna
1 Reply
Did you set it up with WPS? Not all manufacturer's code wps the same and it can create issues. If you set it up via that method, I'd factory reset and try the install using the installation wizard.
