TheMadProphet
Jan 25, 2020Aspirant
How to force devices to connect to EX8000 only
I've asked this in other places, but it seems either folks don't read the entire post or I'm not being clear. I have AT&T fiber and use an AT&T modem. I have a large home and the router is in one c...
- Mar 22, 2020
yes they should all be on one network. The router is the dhcp controller not the ex8000
Jan 25, 2020Guru - Experienced User
What is the best way to ensure the devices connect to the closest WiFi signal?1) should I setup the extender with a different SSID, then connect the devices I want to that SSID? I'm not in favor of this for OCD reasons. :-)
2) should I keep the setup I have and use ACL's on the router and extender? Can I do that? How would it affect those devices that are mobile?
Or am I missing a better option?
the problem is that the EX8000 is more than likely significantly better than the ISP supplied router. As well as the roaming feature is built into the device, not the router. The router supports the roaming standard but its up to the device to switch between router/device.
Best way to make sure devices connect to the extender? Like you said, use a unique ssid for the extender thats seperate from the router.
TheMadProphet
Mar 22, 2020Aspirant
If I have devices connected on the router SSID (net1) and devices connected on the extender SSID (net2), will all devices see each other as though on one network? If not, what about devices that require controlling devices be in the same network? For instance, a camera that requires the viewing device be on the same network as the camera? Force the viewing device to the other network?
- plemansMar 22, 2020Guru - Experienced User
- TheMadProphetMar 22, 2020Aspirant
Thank you for that answer.
The DHCP allocation was what I was about to edit in to my question. My Microsoft TCP/IP classes were literally taken in a different century.Guess I'll find out in a few minutes.
