remo053
Sep 02, 2023Follower
How to have my extender have its own channels separate from my main router.
Trying to get my extender to show as a EXT and separate from my main router on discoverable WiFi connections for my devices. Tried changing the SSID on the nighthawk app with no luck. My extender is...
michaelkenward
Sep 02, 2023Guru - Experienced User
remo053 wrote:
My extender is the Netgear Wi-Fi 5 Booster AC2200.
That's not a Netgear model number.
AC2200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number. It is probably something like EX####
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
You might like to search there for messages related to your problem.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
