Groobe
Mar 18, 2012Aspirant
how to Port forward for IP camera with a WN3000RP?
I have a wireless IP camera from x10 that can't be moved closer to the existing wireless router and needs a range extender to stay on the network due to erratic signal from the SMC router provided by ...
jmizoguchi
Mar 20, 2012Virtuoso
So what do you suggest?
Shorten the distance of extender make sure extender is connect to wireless
Have no idea where the extender has tested etc. Don't place the location you are wanted to work. Get it work 10ft or less line sight such as same room and first if extender is connecting
