Groobe's avatar
Groobe
how to Port forward for IP camera with a WN3000RP?
I have a wireless IP camera from x10 that can't be moved closer to the existing wireless router and needs a range extender to stay on the network due to erratic signal from the SMC router provided by the ISP. My brother bought the WN3000RP and I am able to get the extender to connect to the network, but can't find a NAT or port forward choice in the extender setup to route the camera through it instead of through the home network. It is impressive on the signals it will pick up!
The FAQ here for connection issues in XP pc's helped me get past the Validating Identity issue on connection, but I don't find anything for setting it for port forwarding that helps with this.
We leave very soon and need this working before we leave. I appreciate any help, even if it is to recommend another extender that will work for this.
  • Help;
    I just bought the camera from X-10 and I can't get it to recognize my router. I have tried every setting and still no luck. What are the settings? AES wpk2-psk? Still I can't get it to work? the camera works when connected to the router by cable so it isn't the camera...
    Thanks,
    Also I lost my login and pw to get into my router account. Anyway of a retrieval?
  • Encryption is based on primary router is set to
    Wn3000rp is not a router to refer to manual that you own
  • Thanks I got into the router and checked all settings the upnp is open but not active on the x10 device??
