thierrybodson
Mar 30, 2020Aspirant
How to set up Bridge mode on my second AC2000 R6850
Hi I bought two Netgear AC2000 R6850 WIFI Router. I confirgured the first one and validate everything works fine. I now want to configured my second WIFI Router as a bridge, to have my WIFI ...
- Mar 30, 2020
What you want is extender mode. The R6850 doesn't have extender mode.
Bridge mode uses its wifi to act as a router---router bridge and then only the ethernet ports are usable.
If you can hardwire the R6850 in, then you can place it in AP (access point) mode.
Mar 30, 2020Guru - Experienced User
thierrybodson
"If you can hardwire the R6850 in, then you can place it in AP (access point) mode"
=> I can wire in my both WIFI router to may main Modem/Router.
In such case, my only solution would be to configure two different SSID, one for each WIFI Router (and so hourse level)
Is that correct ?
- plemansMar 30, 2020Guru - Experienced User
Is that correct ?You can set them with the same ssid. You just have to have the 2nd device in AP mode so you don't have 2 routers controlling dhcp. Since your not using a mesh network (like orbi) devices will tend to be a bit sticky but will roam depending on how old they are. newer devices have newer roaming standards.
- thierrybodsonMar 30, 2020Aspirant
plemans wrote:You just have to have the 2nd device in AP mode
How do I switch it in "AP Mode" ?
I don't find any such option in the configuration menu !I see the Type "DHCP" under the "Internet Port" config menu, but can't update it.
page 104 of the manual.
