thierrybodson
Mar 30, 2020Aspirant
How to set up Bridge mode on my second AC2000 R6850
Hi I bought two Netgear AC2000 R6850 WIFI Router. I confirgured the first one and validate everything works fine. I now want to configured my second WIFI Router as a bridge, to have my WIFI ...
- Mar 30, 2020
What you want is extender mode. The R6850 doesn't have extender mode.
Bridge mode uses its wifi to act as a router---router bridge and then only the ethernet ports are usable.
If you can hardwire the R6850 in, then you can place it in AP (access point) mode.
thierrybodson
"If you can hardwire the R6850 in, then you can place it in AP (access point) mode"
=> I can wire in my both WIFI router to may main Modem/Router.
In such case, my only solution would be to configure two different SSID, one for each WIFI Router (and so hourse level)
Is that correct ?
Mar 30, 2020Guru - Experienced User
Is that correct ?
You can set them with the same ssid. You just have to have the 2nd device in AP mode so you don't have 2 routers controlling dhcp. Since your not using a mesh network (like orbi) devices will tend to be a bit sticky but will roam depending on how old they are. newer devices have newer roaming standards.
- thierrybodsonMar 30, 2020Aspirant
plemans wrote:You just have to have the 2nd device in AP mode
How do I switch it in "AP Mode" ?
I don't find any such option in the configuration menu !I see the Type "DHCP" under the "Internet Port" config menu, but can't update it.
- plemansMar 30, 2020Guru - Experienced User
page 104 of the manual.
Thank you,
I look at this.
Really appreciated !
Thierry
