thierrybodson
Mar 30, 2020Aspirant
How to set up Bridge mode on my second AC2000 R6850
Hi I bought two Netgear AC2000 R6850 WIFI Router. I confirgured the first one and validate everything works fine. I now want to configured my second WIFI Router as a bridge, to have my WIFI ...
- Mar 30, 2020
What you want is extender mode. The R6850 doesn't have extender mode.
Bridge mode uses its wifi to act as a router---router bridge and then only the ethernet ports are usable.
If you can hardwire the R6850 in, then you can place it in AP (access point) mode.
Mar 30, 2020Guru - Experienced User
=> I can wire in my both WIFI router to may main Modem/Router.
In such case, my only solution would be to configure two different SSID, one for each WIFI Router (and so hourse level)
Is that correct ?
You can set them with the same ssid. You just have to have the 2nd device in AP mode so you don't have 2 routers controlling dhcp. Since your not using a mesh network (like orbi) devices will tend to be a bit sticky but will roam depending on how old they are. newer devices have newer roaming standards.
thierrybodson
plemans wrote:You just have to have the 2nd device in AP mode
How do I switch it in "AP Mode" ?
I don't find any such option in the configuration menu !
I see the Type "DHCP" under the "Internet Port" config menu, but can't update it.
- plemansMar 30, 2020Guru - Experienced User
page 104 of the manual.
- thierrybodsonMar 30, 2020Aspirant
Thank you,
I look at this.
Really appreciated !
Thierry
Hi Plemans,
If I may ask you a last one.
Since I have:
- One Modem
- On Router ZyXEL (Provided bu my Internet provider, WIFI deactivated)
- Two Netgear AC2000 R6850
And I connect to this router ZyXEL
- One NAS Disk Station
- 1st Netgear AC2000 R6850
- 2nd Netgear AC2000 R6850
>>> Should I configured both Netgear AC2000 R6850 in "Access Point mode" ?
And, may I configured with the same SSID name, so I just see one SSID (well, two for 2.4G and 5G)
Thank you,
Thierry
