thierrybodson
Mar 30, 2020Aspirant
How to set up Bridge mode on my second AC2000 R6850
Hi I bought two Netgear AC2000 R6850 WIFI Router. I confirgured the first one and validate everything works fine. I now want to configured my second WIFI Router as a bridge, to have my WIFI ...
- Mar 30, 2020
What you want is extender mode. The R6850 doesn't have extender mode.
Bridge mode uses its wifi to act as a router---router bridge and then only the ethernet ports are usable.
If you can hardwire the R6850 in, then you can place it in AP (access point) mode.
thierrybodson
Hi Plemans,
If I may ask you a last one.
Since I have:
- One Modem
- On Router ZyXEL (Provided bu my Internet provider, WIFI deactivated)
- Two Netgear AC2000 R6850
And I connect to this router ZyXEL
- One NAS Disk Station
- 1st Netgear AC2000 R6850
- 2nd Netgear AC2000 R6850
>>> Should I configured both Netgear AC2000 R6850 in "Access Point mode" ?
And, may I configured with the same SSID name, so I just see one SSID (well, two for 2.4G and 5G)
Thank you,
Thierry
Mar 31, 2020Guru - Experienced User
thierrybodson wrote:Hi Plemans,
Since I have:
- One Modem
Thank you,
Thierry
Yes if your zyxel is functioning in router mode, you'd want both R6850's in ap mode.
again, you sure can use the same ssid for both devices. They'll be more "sticky" than a mesh device but you can use the same ssid.
