MotoRider42HC
Sep 05, 2018Aspirant
How To Setup A Network For Building-To-Building?
(This is not about the Orbi or Range Extender, i did not know where else to post for help.)
This is my current network map:
Internet > Orbi Router > Orbi Satellite >
...through glass do...
Sep 05, 2018Guru - Experienced User
MotoRider42HC wrote:
Are there any devices that can do what I need? Any kind of outdoor antenna that connects to an indoor router? Or some kind of Repeater with a very specific mode that acts like a wireless adapter? Or some kind of wireless bridge
I've tried a "WiFi Repeater" from Ubiquiti,
Well, if you are using a radio link, you need to mount at least the antenna outside and run a cable to it.
Ubiquiti also has an NanoBeam product line (not a repeater) which is designed to create a point-to-point wireless link that you connect up with ethernet on both ends. It is designed for outdoor use, and receives the ethernet and power over a single cable (Power over Ethernet). Note I haven't ever used this product, so this is not a recommendation - just a suggestion for followup up. https://www.ubnt.com/airmax/nanobeam-ac-gen2/ and https://dl.ubnt.com/guides/NanoBeam_Gen2/NanoBeam_5AC-Gen2_QSG.pdf
Something along these lines would extend ethernet to the remote building. You could then place one of your existing Orbi satellites in the remote building, connecting it to the main Orbi Router using ethernet backhaul (running over the point-to-point bridge).
If the remote building uses the same power distribution, you could perhaps also look into powerline networking.
- MotoRider42HCSep 05, 2018Aspirant
Stephen,
You mentioned a Radio Link. Do you have a part or model number for that device? I'v e seen lots of outdoor antenna options that have the standard female connector that you would screw into an adapter. I guess that Radio Link is the adapter i've been looking for? Would that Radio Link allow me to connect an Ethernet cable to it, then feed that to a router?
For the backhaul option for the Orbi mesh... Do i have to connect the backhaul to the main router, or can I cannect the backhaul between two satellites?
Thanks for the help!
- StephenBSep 05, 2018Guru - Experienced User
MotoRider42HC wrote:You mentioned a Radio Link. Do you have a part or model number for that device?
No. Just the NanoStation link above(which is an integrated antenna and radio system). Again, this is not a product I've used myself.
That's exactly what the NanoStation does. Ethernet connected at both sides, with a radio link in between. The ethernet can be connected to a switch, router, whatever. The radios do need PoE, but you can use a power injector. Not sure if one is included in the box (and if you get your own you would want to contact the vendor and make sure it is compatible).
Not sure if you can do ethernet backhaul to another satellite - that's not something I've done. It'll perform best if you can reach the router.
