slowtolearn
Sep 10, 2011Novice
How to setup WN3000RP wireless extender
I have had no luck setting up the extender. I have an older D-Link router and a computer with Windows 7. I initiated the extender by linking to it through the computer. The directions said that if I o...
xXxDieselxXx
Sep 10, 2011Observer
slowtolearn wrote: I have had no luck setting up the extender. I have an older D-Link router and a computer with Windows 7. I initiated the extender by linking to it through the computer. The directions said that if I open a browser window I would get to the setup wizard, but that did not happen. The fix was to just type in www.mywifiext.net into the browser, but again no luck getting to the wizard. Can anyone suggest the next step?
Hi,
I just setup mine yesterday and had the same issue. The www.mywifiext.net did not work for me so I had to go via IP Address.
Check in your main router what's the IP of the extender then just go to your browser and type in the address and hit enter. That should take you to the main menu.
Hopefully this will help.
