slowtolearn
Sep 10, 2011Novice
How to setup WN3000RP wireless extender
I have had no luck setting up the extender. I have an older D-Link router and a computer with Windows 7. I initiated the extender by linking to it through the computer. The directions said that if I o...
jmizoguchi
Sep 19, 2011Virtuoso
you do not need know the IP of the extender to access.
have pc connected to the extender and by typing mywifiext.com should bring up the interface
you can google angry ip scanner and scan your network if you have difficult finding your extender. you may need to scan outside of the subnet .
also extender should be on DHCP client so likely that it is on your existing network if you were already connected the extender to your existing wireless network.
How do I change my setup after the Extender is up and running?
Make sure you are on a PC that is connected to the Extender network and your PC is configured as DHCP client mode. In your browser, type the URL http://www.mywifiext.net. If you still cannot access the Extender, close your browser. Then open a new browser and type the URL http://www.mywifiext.net.
