RayinWi
Jan 23, 2022Tutor
How to tell if my Win 10 laptop is connected to an access point or a router
I have a router that resides two floors away from where my laptop sits. I get pretty iffy wifi \ Internet speeds because of the distance. I ran a cat 6 ethernet cable from the router to a jack whic...
- Jan 23, 2022
You could log into the access point and check it.
Or you could simply change the access points SSID so you can tell which you're connected to.
RayinWi
Jan 24, 2022Tutor
I tried things a second time and I see that you are absolutly correct about being able to "see" devices that are using the access point. (I don't know how I missed that. Sorry.)
Once I am logged on to the access point then its simply a matter of ....
Expanding "Settings"
Clicking on "Connected Devices"
And then scrolling down to "WiFi Devices"
I can't thank you enough.
Jan 24, 2022Guru - Experienced User
glad it worked!
