ammie915
Nov 08, 2017Follower
How to update the firmware of my Ex7300 extender ?
My new wifi range extender which is EX7300 is having all four solid green lights on it which means it is configured but still I keep on loosing internet on it which is very annoying to me . I was told...
DarrenM
Nov 14, 2017Sr. NETGEAR Moderator
try connecting to 192.168.1.250 and that should prompt the extenders login.
DarrenM
- DJ_ShaveDec 03, 2017Aspirant
Attempting to check the firmware in my extender; EX7300 – AC2200 Nighthawk X4 WiFi Range Extender / Serial # 4FM4685E01A6F and cannot access the device.
Tried the suggested address (192.168.1.250) ... getting 403 Forbidden. Had also tried the Netgear directions ( www.mywifiext.net etc ) without success / response "You are not connected to your extender's WiFi network"
Am connected to the Extender as directed but with no luck.
What's next?
Thanks!
ps: the above note is from my desktop server (Dell Inspiron, Win10 etc) ... access to the extender using my laptop (Chromebook) succeeded
