Jade12
Dec 27, 2020Follower
How to use AC1200 WiFi Range extender modell EX6150 v2 in Access Point Mode
Hi, I try to improve my Wifi network at home using between the router and the extender an ethernet cable (through some thick walls) and using after the extender connected to an existing WiFi network...
Dec 27, 2020Guru - Experienced User
Try this.
1. make sure the switch on the side is in access point mode.
2. Factory reset the extender. Push and hold reset for 7-15 seconds while its powered on.
3. try reinstalling it/setting it up.
