radumaz
Nov 19, 2022Initiate
How to use EX7000 as a switch?
After reconfiguring my local network I have an unused EX7000. Can I use it as an ethernet switch (only wired, no wifi) ? Are there any specific ports for in and out?
radumaz
Nov 23, 2022Initiate
Thanks. What about the wired connection speed in switch configuration? Does it go over 100Mbps? There are no specs for this configuration. My gateway/network is capable of 400Mbps.
Nov 24, 2022Guru - Experienced User
The EX7000 has gigabit ports. If they're only connecting at 100mbps speeds, check your cables.
Move the ex7000 right next to the router and connect it with 2 known good 6ft cables (one from router--extender and other from extender---device) and test the speeds.
