Gavilan101
Jul 08, 2012Follower
How to use Netgear DGN1000 as an Access Point
Hi All, I was hoping someone could help me out with the following I have a Netgear DGN1000 and I want to use it as an Access Point using a wired Lan Cable Its this possible? If so could yo...
Marto731
Jul 09, 2012Aspirant
Gavilian,
For my feedback, will you let me know if you succeeded.
(1) You cannot have anything plugged into the DGN1000 WAN port.
Your incoming cable, must come in on LAN.
(2) I'm lukewarm about using Routers as Access points. :confused:
http://www.netgear.com/home/products/switches-and-access-points/access-points/default.aspx
Regards, Marto
Regards, Marto
