REC639
Sep 14, 2020Tutor
I cannot connect AX1800 WiFi Mesh Extender wirelessly to ATT U-verse router through apple nighthawk
I cannot connect AX1800 WiFi Mesh Extender wirelessly to ATT U-verse router through apple nighthawk app on Iphone 10 Xs. Has anyone else experienced this same problem? If so, how did you resolve the ...
REC639
Sep 14, 2020Tutor
I am going through set up using nighthawk app on Iphone, at the point of using Netgear ext. I'm not able to log in to it becuase "password is not correct". However I can log in to Netgear account OK. I did try to use WPS assistance with no luck. For the firmware, I'm not sure what that is. Standards-base WiFi Security(802.11,128 bit AES encryption with PKS? Right now I do have it hooked up directly to the router via cable.
Thank you for your assistance :-)
Sep 14, 2020Guru - Experienced User
If you're hardwiring it into the router, then you need to set it up in access point mode.
If you plan on using it as a wireless extender, then disconnect it from the router. I just meant to hardwire a pc/laptop into it for setup instead of using the app. Tends to go smoother. Just make sure to disable the wifi on the pc/laptop you connect to it so it doesn't defautl back to the wireless during setup.
- REC639Sep 14, 2020Tutor
I'll try that and get back to you and let you know how things went.
Thank you :-)
