REC639
Sep 14, 2020Tutor
I cannot connect AX1800 WiFi Mesh Extender wirelessly to ATT U-verse router through apple nighthawk
I cannot connect AX1800 WiFi Mesh Extender wirelessly to ATT U-verse router through apple nighthawk app on Iphone 10 Xs. Has anyone else experienced this same problem? If so, how did you resolve the ...
Sep 14, 2020Guru - Experienced User
If you're hardwiring it into the router, then you need to set it up in access point mode.
If you plan on using it as a wireless extender, then disconnect it from the router. I just meant to hardwire a pc/laptop into it for setup instead of using the app. Tends to go smoother. Just make sure to disable the wifi on the pc/laptop you connect to it so it doesn't defautl back to the wireless during setup.
REC639
Sep 14, 2020Tutor
I'll try that and get back to you and let you know how things went.
Thank you :-)
