mystique32
Oct 18, 2021Follower
I can't access the my wifiext.net or 192.168.1.250 to login to the extender?
I can't access the my wifi ext.net or 192.168.1.250 to login to the extender. I've tried Internet Explorer, I've tried Chrome, I've tried Firefox. Every single time I get a "The Connection Has Tim...
Oct 18, 2021Guru - Experienced User
First try factory resetting the device.
Push and hold reset for 7-15 seconds while its powered on.
Maybe it has old settings causing issues .
then try connecting to the netgear_ext via wifi or hardwiring in. that should get you connected to the extender where you can go through setup.
