Maxk9's avatar
Maxk9
Follower
Jan 12, 2020
I cant change my wifi extender password ex2700
I use  my****.net open a window , use my pass and user can't let me in the page.
1 Reply
  • plemans's avatar
    Did you change the password when you set it up? default login is admin and default password is password.  They are case sensitive.
    did you setup the password recovery option? If you get the password wrong enough, it gives you the option to recover your password.
    If you changed the password and didn't setup password recovery, then your option to get into the extender is to factory reset it back to defaults and redo your install.
