ghostking161822
Feb 01, 2026Follower
I can't connect my wifi extender to my router
I can not connect my wifi extender to my router
Feb 02, 2026Guru - Experienced User
And what router do you have?
What method of setup are you using? WPS, the app, installation assistant?
What makes you think it has failed? IE, what error or what are you seeing.
Details are key for any online help setup. So the more you tell us, the better we can help you.
