andrewki
May 30, 2024Guide
I can't extend the wifi signal of a WAX610 with an AX1600 Wifi Extender
Hello, I am trying to set up an AX1600 as a wifi extender to my closest Wax610 access point. The nighthawk app finds the Wax610 powered network ok (both 2.4 and 5) but when I enter the wifi passwords...
- May 30, 2024
Factory reset the AX1600 and install it with the installation assistant and not the app.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
May 30, 2024Guru - Experienced User
andrewki
May 30, 2024Guide
Thank you! I will give that a go and report back. Andrew
- andrewkiMay 30, 2024Guide
OK it seems to indicate that it has worked this time (no password error!):
However I checked for a firmware update and it says:
So is it set up correctly?
Thank you!- plemansMay 30, 2024Guru - Experienced User
what firmware version are you on? You can manually log in and look and upgrade if needed.
You might be getting the "no internet" because you're using business grade access point. I don't know what setting you're using on that or your main gateway.
Got it - thank you. Yes I'm on the latest firmware but was worried about the message. Thank you very much for your help! Andrew
