rogercorke
Dec 21, 2022Guide
I can't log onto my netgear extended with my password
I have recently changed my broadband router. I reset my Netgear extender and connected it to the new router. On my Mac and my iPhone i can see the extender with the same name as the new router, foll...
- Dec 22, 2022
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Dec 22, 2022Guru - Experienced User
