rogercorke
Dec 21, 2022Guide
I can't log onto my netgear extended with my password
I have recently changed my broadband router. I reset my Netgear extender and connected it to the new router. On my Mac and my iPhone i can see the extender with the same name as the new router, foll...
- Dec 22, 2022
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
rogercorke
Dec 22, 2022Guide
Thanks so much. That worked! My router has a WPS button and will connect to the extender using it, so goodness why it won't then set up properly but it just won't.
I would advise anyone NOT to use the instructions to connect through WPS and just use the installation assistant because you waste so much time...the router has a WPS button and will connect when you press it but the extender just won't work., so you wonder what the problem is and spend ages trying to solve it. By using the assistant, you're connected in minutes.
Dec 22, 2022Guru - Experienced User
Glad it worked for you!
WPS can get coded different/poorly so when it doesn't work, its worth trying the assistant.
