stephani1017
Aug 27, 2022Follower
i have a ac750 model ex3110 install fine but now "device" light isnt on and i cant use the install
i have a ac750 model ex3110 install fine but now "device" light isnt on and i cant use the install wizard because i connect to the netgear ext and it wont let me go to the mywifi page can someone hel...
Aug 28, 2022Guru - Experienced User
Have you tried simply factory resetting it and reinstalling it? (to reset, push and hold reset for 7-15 seconds while powered on)
I'd recommend installing it using the installation assistant and not wps.
