jake_b
Dec 28, 2020Aspirant
I have a netgear wifi extender ex2700 \
I have a netgear wifi extender ex2700 and i connected it to my wifi throught the web and it said it connect succesfully and when i tried to connect to it keeps on saying no internet and i have factor...
Dec 29, 2020Guru - Experienced User
What modem/gateway do you have?
What router are you connecting it to?
What firmware is on the extender?
- jake_bDec 29, 2020AspirantI have a modem that is a netgear one, I don’t know which firmware it’s on and I’m connecting it to an asus router.
- plemansDec 29, 2020Guru - Experienced User
jake_b wrote:
I have a modem that is a netgear one, I don’t know which firmware it’s on and I’m connecting it to an asus router.Well, that wasn't at all helpful.
Which netgear modem?
What asus router?
The firmware is found on the status page of the extender. If you did try installing using the installation assistant, you'd have seen it on that page. Did you actually try installing using the installation assistant?
Does it matter based on my motem or router? Or firmware?
