jake_b
Dec 28, 2020Aspirant
I have a netgear wifi extender ex2700 \
I have a netgear wifi extender ex2700 and i connected it to my wifi throught the web and it said it connect succesfully and when i tried to connect to it keeps on saying no internet and i have factor...
Dec 29, 2020Guru - Experienced User
What modem/gateway do you have?
What router are you connecting it to?
What firmware is on the extender?
jake_b
Dec 29, 2020Aspirant
I have a modem that is a netgear one, I don’t know which firmware it’s on and I’m connecting it to an asus router.
- plemansDec 29, 2020Guru - Experienced User
jake_b wrote:
I have a modem that is a netgear one, I don’t know which firmware it’s on and I’m connecting it to an asus router.Well, that wasn't at all helpful.
Which netgear modem?
What asus router?
The firmware is found on the status page of the extender. If you did try installing using the installation assistant, you'd have seen it on that page. Did you actually try installing using the installation assistant?
- jake_bDec 29, 2020Aspirant
Does it matter based on my motem or router? Or firmware?
Yes it does matter. Some routers are mesh or won't work with other extenders.
Or if you're in a double nat situation (which would still connect but can cause issues)
As well as clarity on details of whether you actually did use the installation assistant.
Plus this is the public forum where members of the public help out for free. With our free time.
If your not willing to even look or try, why should I use my time to help you when theres others who are willing to do a little bit of work on their end? Frankly, I prefer to help people who want help and are willing to participate. People who post with attitude or minimal details, I tend to ignore their posts and move on.
