samueljps
Dec 05, 2018Aspirant
I have AC1900 Nighthawk Rtr but need to extend, so what to buy? Orbi System or Nighthawk extender?
Hi guys,
I need to extend the coverage of my AC1900 Nighthawk, looking to see if I should buy Orby System or a NightHawk extender?
If I have to buy Orby System to replace my current router, I ne...
samueljps
Dec 06, 2018Aspirant
Hi Stephen,
Thanks again.
Couple of questions, we have Apple Products, the drop on speed will be really bad? Right now we connect to the Netgear NightHawk AC1900 with no issues but I can see sometimes is slow.
By other hand, if I already have that dual band router, adding EX8000 extender, is not better since I already have a decent router (Yes, just dual band).
Finally, why RBK40 or RBK50 and not RBK23W? Just asking.
Really appreciate your help.
Samuel
Dec 06, 2018Guru - Experienced User
samueljps wrote:Couple of questions, we have Apple Products, the drop on speed will be really bad?
This is specific to the Macbook Pro, not other Apple Products. Though I haven't seen the wifi specs on the refreshed MacBooks.
I don't have these products, and I am getting 300 mbps wifi throughput (or better) with 2x2 802.11ac. What speeds are you getting near the current router with speedtest.net?
That is an option (as I said). The RBK50 backhaul in particular is 4x4 802.11ac, which would outperform the router<->ex8000 leg of the extender connection. The other aspect is that the router's 5G radio is shared between the EX8000 and the clients nearby the router (and that radio can only do one thing at a time). Those tilt me towards the Orbi. It would be more expensive though, and the EX8000 should also deliver good wifi.
It doesn't have the LAN ports you need (only two on the router, not four).
- samueljpsDec 06, 2018Aspirant
Hi Stephen,
I am just getting 130Mbps.
Got it. Those RBK50 or RBK40, has any VPN functionalities or some other security features that I can configure like the NightHawk 1900?
I didnt understand this part ->
But it seems that Orbi is the way to go.
Samuel
- StephenBDec 07, 2018Guru - Experienced User
samueljps wrote:I am just getting 130Mbps.
That is likely limited by your internet service, not by your Nighthawk.
Yes. Like the Nighthawks, Orbis include OpenVPN and DDNS support. They also have the usual MAC address controls, and they include the same options for parental controls. The user guide (covering all Orbi home systems) is here: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
One thing I didn't mention is that Orbi can also give you a guest network throughout your coverage area. The EX8000 can't extend both the home network and the guest network.
With WiFi (at least until mu-mimo), the router can only communicate with one device at a time over each radio. Everything connected to the EX8000 would have all it's traffic forwarded to the router on the 5G radio. In addition, any 5G wifi devices near the router would be directly connected through the same radio. If you have enough devices connected, that could become a performance bottleneck.
Until recently, the focus of WiFi improvements was to increase raw speed of individual devices. That still matters of course, but for most uses 802.11ac 2x2 is fast enough. The focus now has largely shifted to handling more clients with good performance (system capacity). That shift started with enterprises (including hotels, airports, stadiums, etc), but IoT is driving that emphasis into the home products too. Smart home folks need good full-house WiFi coverage 24x7 (also some outdoor coverage if they have a WiFi security system), and they have lots of devices connecting to their WiFi.
Triband is part of the response to that shift - two independent 5 Ghz radios can handle more simultaneous connections then one faster 5 Ghz radio. Mesh technology (both fully integrated mesh systems like Orbi, and mesh extenders like the EX8000) is also part of it.
The emerging 802.11ax standard (just being completed, with first-generation implementations in the newest "ax" Nighthawks) also is aimed at "high density deployments".
- samueljpsDec 07, 2018AspirantHi Stephen,
Your help has been outstanding , really great. I am
Going to compare RBK50 vs RBK40 and take a decision to get one of those.
Sincerely,
Samuel
