kamarkie
Dec 30, 2020Follower
I Need Help Getting My Netgear Extender Model EX6200 To Work
Note 1: My router does have a WPS button. (Windstream Wi-Fi Modem – T3200) Note 2: My extender is located approximately 6 feet from my router. Note 3: My router supports both 2.4 GHZ and 5 GHZ band...
Dec 31, 2020Guru - Experienced User
don't use wps. it doesn't always get codedt he same and ISP supplied devices are notorious for this.
try installing it using the installation assistant. Factory reset the extender (push and hold reset for 7-15 seconds), then try the assistant
https://www.netgear.com/support/product/ex6200
