LauraG
Sep 22, 2020Aspirant
I need to reset my EX 7000 range extender and then set it up on a new network. How is this done?
Hello, I recently had to reconfigure my home network and remove the old network and replace it with a new one. Do I need to completely factory reset my EX 7000 Extender in order to install i...
Sep 22, 2020Guru - Experienced User
You don't need to factory reset to reinstall it but it tends to go smoother.
to reset, simply push and hold reset for 7-15 seconds while its fully powered on.
then follow the install guide found here: https://www.netgear.com/support/product/EX7000.aspx
LauraG
Thank you
