skott79
Dec 07, 2019Guide
I own the EX7700 & added the EX800, now I'm having Internet drops
Hi, I own the Nighthawk XR700 router and about 8 months ago I added the EX7700 to get a better signal in my back office. It's worked great but I was still getting weak signal on wifi calling in ...
skott79
Dec 07, 2019Guide
I said “said” and I meant “seen.” When I said I’ve read that you can have two extenders on one network was meant if you don’t have over lap in their signals (based off of what I read on the forums here).
Anyway, that being said, is it possible to create a full mesh network with the setup of extenders and router I have? I saw you mentioned that as a solution.
For now I disabled my EX7700 and I’m just running my Nighthawk XR700 with the EX8000.
Dec 07, 2019Guru - Experienced User
The mesh extenders aren't a true mesh setup. its kind of a hybrid. You can't really create a full mesh network setup using multiple extenders and a router that isn't designed for it. They work great when its just a single router and a single extender. As you've found out, it gets more complicated when you add a 2nd extender and they can pick up the other extenders signal.
A true mesh network is something like Netgear Orbi or a different vendors mesh solution.
You can keep using your EX7700 but all you'd need to do is change its broadcast ssid to something else from your main router and the EX8000.
You didn't put what router you have but if its not the best router, potentially you could shut off the routers wifi and put the EX7700 or EX8000 in ap mode and use the other extender to connect to that. They both have pretty decent radios in them and are triband. Maybe you'd get better coverage this route. Not sure though and it might take some experimentation.
- skott79Dec 07, 2019GuideI think you may missed what router I had, it’s the Nighthawk XR700... listed it up above. It’s a fantastic router, I have gigabit internet and it does the job.
Thanks for the help!- plemansDec 07, 2019Guru - Experienced User
whoops, i did miss that. yes it is a great router.
- skott79Dec 07, 2019GuideNo worries.
Thanks again for all of the replies.
My long-term goal is to have a wide reaching network once I move my office out of my house in to a finished tuff shed in my backyard, so it’s sounds like I either need to buy a proper mesh network or bury an Ethernet cable from my extender out to the my new office (which will be closest to where the EX8000 is).
