STINKEYE
Nov 21, 2019Aspirant
I switched my r6700v2 as an access point but I still see the primary router's wireless signal?
Disclaimer: I'm a total noob at this so please don't judge. Hello, I just had cable installed on my house and the cable company provided me with a modem and router. I have a 2 story home and the...
Nov 21, 2019Guru - Experienced User
If you switched your R6700v2 to AP mode, all you've done is disabled some features of the router.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
it didn't do a thing to the spectrum device other than avoid a double nat situation.
https://kb.netgear.com/30186/What-is-Double-NAT
You've got a couple options. If you like having the added coverage for your wireless, just log into each device and setup their own ssid and place their wireless radios on different channels. this limits interference and keeps them functioning well.
if you've got plenty of coverage with just the R6700, you can always disable the wifi on the spectrum device.
Or if you want to get more complicated, you can place the spectrum router/modem in modem only mode, and turn routing mode back on the R6700.
