STINKEYE
Nov 21, 2019Aspirant
I switched my r6700v2 as an access point but I still see the primary router's wireless signal?
Disclaimer: I'm a total noob at this so please don't judge. Hello, I just had cable installed on my house and the cable company provided me with a modem and router. I have a 2 story home and the...
Nov 21, 2019Guru - Experienced User
and this would be your forum. You're currently posting in the wireless extender forum.
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- STINKEYENov 21, 2019Aspirant
Thank you Plemans for your response and I appologize for creating this post on the wrong section.
So, based on my basic understanding, even if I "setup their own ssid and place their wireless radios on different channels" this will not stop me from having 2 wirless networks, correct? My idea was to have a router in a central location (the loft) that will cover the whole house. The garage is in one corner of the house and my room is in the opposite corner upstairs, my home is 3100 sqft.
- plemansNov 21, 2019Guru - Experienced User
it would have different ssid's (wireless names). 3100 sq ft is a large area to cover with a single router. If they're on different wireless channels, they're not going to interfere with each other and always give you the option of a backup wireless to use on that end of the house if need be. You could always name it something like "backup". Or you could just disable the wireless through the settings.
Thank you again!
I think I'll do what you said and have one as a back up. My only concern will be having 2 netwroks run simultaneously will slow the internet down since i'll be splitting the signal. Unless I turn the wirelss of and on like you said.
