STINKEYE
Nov 21, 2019Aspirant
I switched my r6700v2 as an access point but I still see the primary router's wireless signal?
Disclaimer: I'm a total noob at this so please don't judge. Hello, I just had cable installed on my house and the cable company provided me with a modem and router. I have a 2 story home and the...
STINKEYE
Thank you Plemans for your response and I appologize for creating this post on the wrong section.
So, based on my basic understanding, even if I "setup their own ssid and place their wireless radios on different channels" this will not stop me from having 2 wirless networks, correct? My idea was to have a router in a central location (the loft) that will cover the whole house. The garage is in one corner of the house and my room is in the opposite corner upstairs, my home is 3100 sqft.
Nov 21, 2019Guru - Experienced User
it would have different ssid's (wireless names). 3100 sq ft is a large area to cover with a single router. If they're on different wireless channels, they're not going to interfere with each other and always give you the option of a backup wireless to use on that end of the house if need be. You could always name it something like "backup". Or you could just disable the wireless through the settings.
- STINKEYENov 21, 2019Aspirant
Thank you again!
I think I'll do what you said and have one as a back up. My only concern will be having 2 netwroks run simultaneously will slow the internet down since i'll be splitting the signal. Unless I turn the wirelss of and on like you said.
- plemansNov 21, 2019Guru - Experienced User
your not going to lower your speeds by running 2 wireless networks. Running wireless doesn't use any bandwidth unless something is connected and utilizing it. the only "but" to this is if you're primary router is running QoS (quality of service) that restricts bandwidth by device. Usually you can disable this feature.
Just make sure to seperate the wireless radios by channel.
So put your spectrums 2.4ghz on channel 1 or 11 and your netgears on channel 6.
For the 5ghz you should be able to put on on the lower spectrum 5ghz (36-48) and the other on the higher spectrum (149-161).
