KarelH
Aug 17, 2019Aspirant
I use de wifi extender on a camping. Connecting to wifi needs 3 steps: SSID name + login password +
I use the wifi extender on a camping. Connecting wifi needs 3 steps: SSID name + passwordname + a personal code to type in the website of the camping. I can not reach this last step. Wat Works? Hoe to?
- Christian_RNETGEAR Employee Retired
Hi KarelH - Would you mind providing us with the model number of your extender.
~Christian
- KarelHAspirant
Thank you for your attention, Hope you can help with this model number.
Karel
KarelH - You may try a factory reset on the extender. To factory reset the extender, start by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
Furthermore, please provide a screenshot of the page that requests for a personal code.
~Christian
- KarelHAspirant
Your advise to reset the extender worked! Can be interessting fort others: ïf using the extender on different places olways reset to factory and install new connection to router.
By the way: are there models on sale which have this multi-location-function standard???
Greeting,
Karel
