A_W
Dec 20, 2020Aspirant
I want to return my product/ sell it on
I have a Tri band Wifi Router that I bought from JBHIFI just over 6 months ago and a more recent purchase from Ebay of an Orbi System add on. They are compatable but the system is absolute rubbish an...
Dec 20, 2020Guru - Experienced User
We potentially can help get them running better but if you're done with them, you can sell them.
I'd factory reset the (push and hold reset for 7-15 seconds while powered on).
That'd clear out your info from them.
the registration doesn't pass on but warranty isn't transferable so its kind of mute point anyway.
- A_WDec 27, 2020Aspirant
Thank you for the advise, I will definitely do the reset.
I highly doubt you can get them to work better, but I appreciate the sentiment.
