A1J3K4
Jan 04, 2022Follower
/ia_hijack.htm
I apologise in advance for a very dumb/newbie question. When I am trying to connect my Netgear AC1200 WiFi Ext to my new Router, I type in wifiext.net and when I enter it comes up with the extens...
- Jan 04, 2022
During the extender installation, or in case the extender was not able to connect to the primary router, it'll often takes you to to URLs like http://www.mywifiext.net/start.htm or http://www.mywifiext.net/IA_hijack.htm ... Note: This is the correct URL 8-)
schumaku
Jan 04, 2022Guru - Experienced User
- nielsvdsJan 06, 2022LuminaryAre you using the genie app?
