StAlphonzo
Dec 07, 2021Aspirant
Incorrect Password
I can't login to the extender. The instructions say the password is the same as my wireless router. I have verified that I am using the correct password. After many tries I still can't login. Any hel...
StAlphonzo
When trying to connect to my extender with my phone I am asked for the extender password only. No username. The manual says my password is the same as my wireless router and it isn’t. Other ideas?
Thanks
Thanks
Dec 08, 2021Guru - Experienced User
I've seen WPS get coded differently between manufacturers. Try factory resetting the extender (push and hold reset for 7-15 seconds while powered on).
then install it using the installation assistant and NOT wps.
