Josiah0455
Sep 10, 2020Aspirant
Incorrect WiFi password
My devices keep getting disconnected and it says my password is incorrect. I preceded to type in the correct password and it says it’s still incorrect. This just started happening recently I’m not sur...
Sep 11, 2020Guru - Experienced User
What router is it connected to?
Did you set it up via wps?
have you tried factory resetting it and reinstalling it using the install assistant?
- Josiah0455Sep 11, 2020AspirantThe router that is being used is a spectrum wave 2 connected to the netgear range extender and I do believe that it was set up with a wps. I have factory reset both the router and the extended multiple times. I’m not sure what the install assistant is.
- plemansSep 11, 2020Guru - Experienced User
this article walks you through it
- Josiah0455Sep 11, 2020AspirantThe article just describes the two different ways I normally set up the extender.
