Josiah0455
Sep 10, 2020Aspirant
Incorrect WiFi password
My devices keep getting disconnected and it says my password is incorrect. I preceded to type in the correct password and it says it’s still incorrect. This just started happening recently I’m not sur...
Josiah0455
Sep 11, 2020Aspirant
The router that is being used is a spectrum wave 2 connected to the netgear range extender and I do believe that it was set up with a wps. I have factory reset both the router and the extended multiple times. I’m not sure what the install assistant is.
Sep 11, 2020Guru - Experienced User
this article walks you through it
- Josiah0455Sep 11, 2020AspirantThe article just describes the two different ways I normally set up the extender.
- plemansSep 12, 2020Guru - Experienced User
which spectrum modem/router is it?
- Josiah0455Sep 12, 2020AspirantSpectrum wave 2
