Josiah0455
Sep 10, 2020Aspirant
Incorrect WiFi password
My devices keep getting disconnected and it says my password is incorrect. I preceded to type in the correct password and it says it’s still incorrect. This just started happening recently I’m not sur...
witwitchery
Dec 15, 2020Tutor
Well, looks like I spoke too soon. It worked fine last night after resetting it, but now it's not working at all. The lights are still on on the unit, but I can't connect to my IP address or to mywifiext and the Netgear extender login page says I'm not connected to the extender. I've tried their troubleshooting tips to no avail.
Dec 16, 2020Guru - Experienced User
Are you on version 1.0.0.210 of the firmware?
If so, downgrade tot he 1.0.0.206 version, factory reset, and reinstall. After reinstall, disable auto-updates. I've seen a coupe posts where people are having issues on the latest firmware.
