Mfrick
Dec 26, 2022Tutor
Install error reset "1"
I have an N300 wifi extender. It's was working but recently I couldn't connect to it. I tried the install assistant and got 'reset' ("1"). Did a factory reset. Tried again to connect thru the browser ...
- Dec 28, 2022I will accept but still baffled why it doesn't work using my phone. Thanks.
Dec 27, 2022Guru - Experienced User
1. what N300 device do you have? n300 is a speed, not a model
2. what firmware is on it?
3. what is giving you that error? Do you have a screen snip of it?
4. what router are you connecting it to?
- MfrickDec 27, 2022TutorRouter: VIASTAT ADP-90AR<br>Extender: WN3000RPv3<br>Plugged in extender. Green light on.<br><br>I launched my web browser<br>MYWIFIEXT<br>Login page flashes, replaced with a page that only says Reset: ("1") at he top rest of page is blank. <br>
- plemansDec 27, 2022Guru - Experienced User
Take a screensnip of it.
Is the extender disconnected from everything?
Did you hit the wps button at any point? (if so factory reset it)- MfrickDec 27, 2022TutorI was trying to do this on my phone and getting the error. I switched over to my laptop, using the same procedures and now it works. Thanks for your help.
