Mfrick
Dec 26, 2022Tutor
Install error reset "1"
I have an N300 wifi extender. It's was working but recently I couldn't connect to it. I tried the install assistant and got 'reset' ("1"). Did a factory reset. Tried again to connect thru the browser ...
- Dec 28, 2022I will accept but still baffled why it doesn't work using my phone. Thanks.
Mfrick
Dec 27, 2022Tutor
I was trying to do this on my phone and getting the error. I switched over to my laptop, using the same procedures and now it works. Thanks for your help.
Dec 28, 2022Guru - Experienced User
glad you got it working!
You might mark it solved so others aren't still trying to fix it then.
- MfrickDec 28, 2022TutorI will accept but still baffled why it doesn't work using my phone. Thanks.
- plemansDec 28, 2022Guru - Experienced User
It could have been something with the phone itself. ios and android have started going random mac/ip address setups that have caused issues. Plus its tough to know what else on the phone that could be causing it. Its one of the reasons we usually try have people install with the installation assistant if there's issues with either a device or app.
