Newtown27
Apr 09, 2020Follower
installation of Wyze cam will not use netgear 5G
I am trying to install a wyze cam and it will not accept 5gh but requires 2.4 gh network is there something I can do? Thank you
Apr 09, 2020Guru - Experienced User
You didn't put much info.
What device are you using? (model or router/extender that you're connecting to)
Make sure the device you're setting it up on is connected to the 2.4ghz as well.
